I'd suggest bolt on spacers ey... longer studs is getting dangerous
bolt on spacers are the ones with the holes so that the bolt goes flush with the spacers?
I think bolt on means that you bolt them on to the hub, then bolt the wheel onto the hub, as opposed to a long stud
correct!
any brand in mind what i should get?
h&r, ichiba or weds (can get weds from jdmconcept - but they arent hubcentric)
which brisbane people are going on the march clem7 cruise? we should have meetup first then goto first spot together :)
stig, is ur foggies oem or ebay?
hey, whats the center bore size for our FDs?
Get bolt on spacers at your own peril, I just killed a wheel bearing and a contributing factor was the 15mm spacer I was using.
what branded spacers were u using?
