Got mine today...vtec solenoid gasket.... have to order it from melbourne apparently as not lots of honda part dealership keep hold of it... n thx for the guide... PR3 the way to go...
Has anyone needed to fix the y1 gearbox? Mine doesn't want to hold 5th gear anymore. I can engage but once I take the clutch out it pops out.
Looking for the part number or where to find the below:
Y1 Gearbox Oil Filler Bolt
Thanks
i would say any b series filler bolt will fit
With reference to the question I asked above, after doing some research discovered the below:
Honda 92800-20000 (Bolt, Drain plug 20mm) (FILL PLUG)
Honda 94109-20000 (Washer, Drain Plug 20mm) (FILL PLUG)
Honda 94109-14000 (Washer, Drain Plug 14mm) (DRAIN PLUG)
Honda 54110-SH3-003 (Change Lever Ball Seat)
Number 9 in diagram
Honda 54115-SH3-000 (Change Lever Dust Seal B)
Number 13 in diagram
Honda 54111-SH3-000 (Change Ball Holder)
Number 10 in diagram
Honda 46505-SA5-000 (Pedal Stopper Pad)
Rubber piece that turns off brake lights by resting against the switch.
Found these off a honda parts website, then enquired with torque honda part's desk to confirm with my EF9, placed the order and now waiting for them to come in from Japan/Melbourne. Refurbing a few old bit's and pieces, as the gear stick rubber seals/holders seem to have worn out over the last 17 years. Getting it all back to OEM freshness.
http://img126.imageshack.us/img126/7...boltff0.th.jpghttp://img126.imageshack.us/images/thpix.gif
http://img339.imageshack.us/img339/4...gramuy5.th.jpghttp://img339.imageshack.us/images/thpix.gif
ef8 engine mounts???
the one of the front of the car, next to the radiator?
I wasted $60 at autobarn for the wrong mount.
can't return it cos its special order:(
can someone help me out?
I hear that da teg parts are samish??
I just need that mount on the side of the engine/front of the car.......
Bau
Hey Bludger try this site - from pic you need a 50840-SK7-01
http://www.crxsi.com/jdm/
all the part number we will ever need - I did all my mounts from this site and were all spot on - even got the honda dealer to check vin against the numbers i had found and all was good
I found out that its exactly the same as a da9 item with b18a.
EF9 Brake Pad number: DB1133
Front Brake rotor number: DBA474 (262mm)
I need part number for top radiator hose.
ef8
Top radiator hose : 19501-PW0-000
Bottom radiator hose : 19502-PW0-000
i need part number for ef8 clutch cable
