Exellent idea:idea:
http://www.powerbuilttools.co.nz/Images/640422w.jpg
i bought this at work the other week for $75
powerbuilt part no 640422
not too bad, pretty much a rachet set with a hole in the middle
to fit bolts or a screwdriver to do tappets
:D
no, b18c7 should be same as b16a (all dohc b series vtec)
intake : 0.15-0.19mm (0.006-0.007")inch
exhaust : 0.17-0.21mm (0.007-0.008")inch
someone confirm?
Need some help here please....:confused:
I need to comfirm where to slide the feeler gauge to measure for DOHC engine. For SOHC, the attached video is clear enough....:thumbsup:
Can somebody draw on the above picture to show me??? Apparently somewhere between the cam lobe and rocker arm surface....
thanks....
http://b16a2.kicks-ass.net/tech/tappets-h22.jpg
between the yellow arrows
[QUOTE=ECU-MAN;1245216
between the yellow arrows[/QUOTE]
Thanks for that. Just did that in the weekend.
Only the Exhaust valve of the 1st Cylinder is tightened around 0.002 out of spec...
Also, is it normal to hear gas escaping noise as you turn the crankshaft?
yeah its normal
what are the effects of not adjusting the tappet over time ???
fuel efficiency?
noise yeh...
etc???
the lash get out of spec, so a side effect is noise, but what happens to the valve train is much wors. you can damage a rocker arm, valve head posibly the cam as well ( depending on engine manufacture ).
it would take a while to do damage, but it all depends on how out they are
the work shop manuals indicate that the feeler should come in from the center, not the outside (if you get what you i mean)
do you recommend doing it from the outside so it goes between the cam and rocker?
