Hi,
Am using Advan RS 18x8 +45 with 225/40R18 tires on my Euro. Thinking of changing to PS3. Will any of these 3 sizes be an issue of rubbing the fender? I do not want to fender roll. Thanks.
1. 225/45R18
2. 235/45R18
3. 235/40R18
Hi,
1. 225/45R18
2. 235/45R18
3. 235/40R18
Not too sure about rubbing, but I AM sure that you're speedo will be thrown way off. I remember doing some calculations, and it said 225/40R18 or 245/35R18 would be within range. 235/40R18 would throw the speedo off by 5% compared to stock (using 205/55R16 as a base). Going 235/45R18 will mean your speedo will be way off.
I know what you mean, as I'm running the same size tyre, albeit on a 8.5" wide rim. However, if you want to stay within 3% of your speedo, 225/40R18 really is the only way to go, which in itself is 0.84% larger than OEM 16", however going up to a 45 profile would throw you off 4.4%. It would also make your car use more fuel, as the engine has to work harder, and acceleration will be slightly slower as well. Another thing with going wider is that the more track, the more contact with the road which usually means more road noise. It's one of the downsides to going 18" unfortunately. One route you can go down though, would be changing your dampers/shocks to better ones. Especially if you intend to lower your car anyways, shocks influence a cars ride a lot more than a 5% increase in aspect ratio. That and I highly doubt you'll notice much of a difference between a 40 and 45 profile tyre anyways.
As a last resort, as in if you don't want to change shocks and can't deal with the harder ride, then you could always sell your 18" and grab a set of 17s to replace them.
