Originally Posted by Chris_F
I think that the injen illustration is a bit misleading, they sit significantly lower than that, from the pictures i've seen. I think it's safe to say anything below the stock rubber piece will be drawing in cold air. I removed my rubber piece and would now put it back on :p but considering i'll be getting the GruppeM on tomorrow, there's not much point.
The way gruppeM has designed their intake is to place the filter as close as possible to the throttle body (directly attaching to the stock rubber inlet tube) and then as matt said, utilise the stock "intake tube hole" to get cold air. I'll hae to see if the carbon fiber shielding is enough to precent heat soak.. but i'm sure it will be :thumbsup:.
Also the use of the stock inlet tube on the gruppeM makes me wonder if this piece is well designed and not needed to be replaced? Mugen rarely replaces this part on its intake (it doesnt on the DC5R and cl7 intakes).
One final point, is that the CAI's on the market INJEN and K&N both use metal tubing and besides adding extra wait, wouldn't heat soak eventually become an issue as the fairly direct connection to the throttle body would allow heat to conduct through the metal tubing? The gruppeM using all rubber/plastic and carbon fiber coponents could possibly insulate better against heat and reduce intake temperatures :p
