Definitely. What they really are is injectors made by Lucas IIRC that have been finely calibrated to a high tolerance.Quote:
*strokes his injectors while drooling...
A meager 200whp is a little under double stock power for an LS motor (I dyno'd at 114hp for example). 440cc injectors are a little under double the size. The stock fuel pressure regulator is rising rate, so you will be rising in fuel pressure with boost. Stock duty cycle is around 87% or so, so with a higher fuel pressure you'll certainly be close to that magical 80% number.
I definately vote you buy larger ones though. I bought 650cc's for future upgrades since my final goal is around 400whp (hopefully they will be enough with 50psi fuel pressure or so). If your buying new, the price difference is hardly much at all in the scheme of things.
dude
get 550cc ...
i have a turbo dc4 and i am getting 550cc injectors ...
if you want high power and high boost get 550cc injectors
if you want to be a rice burner and just wooosht everyone in the street youll be good with 440
Woo captain knowledge steps up to the plate! That 25% increase in cc rating is surely the difference between a 'rice burner' and 'high power and high boost'. Good choice.Quote:
Originally Posted by integrity
Did I mention I have some RC 550's for sale? ;)
if you want "high power" and "high boost", you're going to need a whole lot bigger than 550cc injectors...
t28 - 440... plenti for it's application :D
We seem to be going around in circles again. ;)
.......Quote:
Originally Posted by Andreas Miko
with the above general guideline, you would at least want to over do your applicatio A BIT... this is coz you don't want your injector duty cycle reaching like 90% at high rpm and then something goes wrong like injector wiring or it goes faulty.... this will lead to fuel starvation and a destroyed engine.
not sure what HP figure your after for your car but as a general STOCKISH bolt on (based on a mates DC2vtir turbo setup VAM05Z) the 440cc would be a good starting point with the added safety.....
im running a gt2832r in mine and 550cc is good to get me to 250kw ATW with a strong driveshaft
fair enough... however what is your injector duty cycle % at peak boost/rpm/KW?? and what is your peak KW that you are getting with this setup?Quote:
if you can provide this info it will tell a good benchmark for everyone to learn from...
