If the mugen doesnt use oil then i would say that one. Always herd the oiled filters can cause problems down the roadQuote:
yes some of the plastic trim can to be removed as its a very tight fit to attach the braces and theirs no way u can do it without removing at least some of the plastic trim in the bonnet. The front piece of plastic where the bonnet lock is HAS to be removed. I also removed the sides plastic bits. Then just re attached them once i was done. Yeah i noticed quite a diff ( some of it mite of been in my head :p ) but the ride just seems stiffer or more rigid. And it doesnt look too bad either! If you want some more pics jst pm me ur email address and ill send them thruQuote:
Originally Posted by xenfacta
could you explain what the difference between a oil filter and normal panel filter work? ive never heard of a oil filter before. thanksQuote:
Originally Posted by davecash
a oil filter filters the oil?
i think civic^^ meant an oiled panel filter vs non oiledQuote:
With the K&N filters you apply oil to the filter to help prevent dust from getting through. This can APPARENTLY cause problems with the MAF Sensor. As the filter already comes pre-oiled you just need to make sure that when it comes time to re-oil it you dont over do it and you give the oil sufficient time to migrate.
i didnt think k&n has brought one out yet, what size is it? i dont see why it would void ur warranty, i had a k&n on the monaro and holden never said a word. its a higher quality filter that requires less maintenance. dont see the prob with that!Quote:
Originally Posted by dannybubu
oh ok thanks davecash, i understand now
K&N Filter 33-2343Quote:
33-2343 Product Specifications
Product Style: Panel Air Filter
Height: 0.875 in (22 mm)
Outside Length: 11 in (279 mm)
Outside Width: 6.25 in (159 mm)
Filter Re-Oiling Amount: 0.86 oz (25 ml)
Weight: 0.9 lb (0.4 kg)
Product Box Length: 13.5 in (343 mm)
Product Box Width: 7.75 in (197 mm)
Product Box Height: 1.75 in (44 mm)
That one fits in the civic sport, not sure bout the vti/vti-L
will it look good by putting white leds on the registration plates instead of the yellowish bulps?
I remember seeing someone doing it to his lexus...looked pretty good on the freeway!
yup.. that's the part number. Ordered mine from a supplier based in the US and I dare say that i'm probably the first to run it in my civic sports :angel:Quote:
Its an oil based air panel but no dramas to the AFM if you don't over-oil if after washing.
highly recommended
Have you noticed much difference? if so, what differencesQuote:
Originally Posted by G_Vtec
We share the same springs with the SI in the states..
