If it fits into a TSX, it will fit an Euro.
Im a bit of a noob with this VTC stuff.
But I am wondering what the price difference would be between these two systems and compare that to cost>?
Im saying, what would each complete system cost to get to each of their respective HP and TQ as represented by the graph? Is the higher HP system equivalent in cost or 2x as expensive? Just interested for future reference.
The dyno chart is from Hondata's tuning research. If you wanted to factor in labour costs, it would be too much for the gains you get. For example, the stock VTC is ground so that it gets up to 45 degrees. The labour of taking it apart and then sending it out to regrind, then getting a k20a ecu with conversion harness in order to use the k-pro with your electronic throttle, tuning and etc. It's a lot of money.
You're better off getting I/H/E and then waiting for a programmable ECU solution to be released or going for a piggyback. This is the route that most of us go for. After you do all this and get a programmable ECU, then consider the modded VTC and/or cams.
