I have the Feel's unit, I'll go to Aaron's place to pick up one and see if 2 ETDs makes a difference....
Hmmm.I wonder if this is worthwhile doing if you have no engine mods?
I decided not to try out MUGEN88's Ingalls ETD because it's not worth my time dropping the driver side suspension just to try it out for a few days, I'll install it straight to MUGEN88's car instead.....
I think I'm gonna have a problem as the guys in the U.S report that it is not compatible with UR pulleys without grinding a bit of the bracket that sits near the pulleys. There is also issues with the brackets touching and rubbibing against the inner hood liner and AC lines of 2006 Euro's onwards.
However it seems that 2003-2005 Euro's may be ok as this was the development model used and there may be slight differences with Euro's 2006 onwards.
Ingalls in the U.S are aware of the problem and I believe are working on it but this is gonna be a while I think.
Damm. :(
so I just bought another etd that doesn´t work?:(
UPDATE:
Well those with UR pulleys will have clearance issues....
So I tried on mine, there were no clearance issues on the stock pulleys... BUT... The bracket that goes on the suspension mount is rubbing badly against the AC line, a fair bit of cutting will be required to clear the AC line..
Right now, I guess is wait and see what/how Ingalls will resolve this issue.
Mine fits fine, no rubbing, no troubles
It's good to hear that you got it on without any issues..
I'll wait for Aaron to come back and see if there are any issues with the AC lines on his car...
P.S... A bigger photo would be nice :)
