2.5 inch fine
3 inch will be the same or much better depending on his parts.
What you are claiming is overkill. Nothing more to discuss.
2.5 inch fine
^ agreed
How does a nismo ballbearing T28 (i think it was a T28) sound?
I was thinking of getting that, and ill just sell the XSpower turbo, get my manifold reinforced, and get a 2.5" exhaust made.
But this will mean i need the T3 flange cut off, and ill have to get a T2 weld on, wont i? Which means i wont need it reinforced, ill just get them to reinforce the new T2 flange welding? Or should i get a T3 -> T2 joiner thing, that goes between turbo and manifold?
Would this be a good plan?
I just thought about this.
That means i will chop off manifold flange, weld on new one, reinforce it, sell turbo, need a new dump pipe+down pipe made up. What is the point in buying this kit in that case.
I might as well just buy an intercooler+ charge piping, scilicone joiners + t clamps, exhaust manifold, get full 2.5" exhaust made up and that will be almost the same price as the kit i think?
What yous recon ?
Far better off not buying that cheap kit and doing what you just said.
You will end up with better quality parts ;)
I have already bought the kit from Kerim 3 weeks ago and getting it installed this Wednesday. So i will be able to tell you more next week.
My setup will include the following:
Kerim Xs turbokit
Sard Fuel regulator
Apexi AFC-Neo
Xforce 2.5" Cat
And i may get the RC 440cc fuel injectors and new fuel pump if required. A clutch and flywheel upgrade are on the list too.
As this stage, I don't what to expect yet.
The guy who is doing the installation have a good setup on his civic with Rev hard manifold and garett turbo. I think this initial setup of my kit will be laggy as the XS turbo is a T3/T4 spec and the intercooler seems too big for the job.
I have been a Nissan Fan for the last 10 years( still is ) but i have recently caught the Honda turbo bug. Civic seems like a good choice with so many things to choice from. You can hop up as much as your budget allows you to and never have to worry about finding parts.
facing back
http://i27.photobucket.com/albums/c1...LN46/ex001.jpg
facing forward (can see cat)
http://i27.photobucket.com/albums/c1...LN46/ex003.jpg
dump pipe
http://i27.photobucket.com/albums/c1...LN46/ex005.jpg
3" going past rear tyre (no it doesnt hit)
http://i27.photobucket.com/albums/c1...LN46/ex007.jpg
muffler
http://i27.photobucket.com/albums/c1...LN46/ex008.jpg
no it wont fit at all :confused:
im just going to direct u to this
My Turbo Build
pretty much goes through every problem u could possible run into.
previously this car was running a xs power kit and i have the xs power turbo sitting in my shed still fully seized from 12 months use in the car.
on this setup i went to us an rb20 turbo second hand, i wouldnt do this again. they dont last very long being second hand, they are cheap but dont expect them to last long.
the kit will work and u will see a good power gain from it, but dont expect to much if ur not willing to put the dosh in it.
http://cgi.ebay.com/ebaymotors/CIVIC...spagenameZWDVW
Would this be a good manifold, but i wount have to get T3 flange + WG adapter cut off, and a T2 flange welded on. Would it be worth it? I cant find a T2 flange, unless someone can point me in the right dirrection. I'd rather avoid ebay parts, and want to try spend under $200.
No that is an SSAUTOCHROME manifold, it is the same as the one in that kit you were looking at.
AVO sell a cast iron manifold that will suit, it is $680 however.
You can't reinforce a manifold, especially those stainless steel ones your talking about. The steel is too thin.
For a decent manifold your looking more than $200.
The AVO one is good for a log manifold, but out of your budget.
Next best thing would be a second hand manifold. Just be careful with any US ones as they sometimes don't fit or you loose a/c & powersteering. If you get a second hand one try making sure it is cast or steam piped, that way you don't have to worry about the manifold cracking due to previous heat stress.
Otherwise your looking at more $$$
