Re hiding the emanage:
You might not see it when the car is whole, but in an accident when the car is in pieces it might be open for the world to see.
errr or tell them about it. i did with my jtune. no issue
hm if i happened to get some cams for example skunk2 stage 1 cams..
would the e-manage be suffecient enough to tune it or would i need v-manage too?
just curious ;)
thats exactly what i want to know!
aparently you need an ecu with adjustable cam advance to fully optimise cams... and the emanage (even ultimate) doesnt have that?
im nearly willing to give stage2 cams a go even without ecu tuning.... but i keep getting burned when i suggest it to people lol maybe you can try it first? lol
only problem ive come accross is that for stage2 cams youll need valve springs (for higher lift) however, the k20a springs dont fit the k24a3 (or so adrian from toda and james from jtune discovered)
Greddy E-Manage Ultimate Complete Harness Set Part no.15901500
Greddy E-Manage Ultimate Unit Part No.15500501
Would this complete harness set be suitable for the euro i am assuming so cause its stated its required for new users?
Thanks all
hey guys,
just wondering with the complete harness set i've been told by Is Motor racing that it requires a field one touch connector CN-13 to fit in the euro?
is that correct?
and they also recommended H-7 harness which is for the DC5 (RSX in the US) which will not need to use that field connector?
Can anyone help me and tell me that it is correct as i do not want to get something that will not work?
Thanks in advance guys!
Anyone know if the our accord euro CL9 ECU connections are similiar to the K20A DC5 or EP3?
Regards, Daz
I doubt that they would be that similar......
yeh i am guessing i'll prob have to get a harness from boomslang.
But does anyone know if its the acura tsx or honda accord k24 harness to choose?
Use the 2004 acura tsx wiring option from boomslang. I'm using it currently, thanks to arronng for the reference. it is direct fit without modification
