Ovrefilled
don't sound good.......Check the rad cap?
oh well, look at the leakdown tests for a headgasket issue...
but make sure your rad cap is working too!
dude i'll prb drop by later in avo if you around
bit of a drive from manly to toda LOL
use the recommend radiator cap.
maybe re-bleed it then?
still an issue Luke ? Dam.
Consider the factors -
engine was "rebuilt" to OEM spec. Car was then boosted.Loose tolerence or issue in the build might be a reason for premature wear / possible HG issue ?
Get a
leakdown test already lol i told u 2 months ago :P
I was right all along!! small leaking headgasket!@!!!!!!!!!
