mugen and gruppeM intake for fd2 ftw :P
do you guys know the best priced place for someone in Oz to source the Typhoon SRI? I was thinking US ebay or something but I hate buying stuff on there.
I don't know, I couldn't tell the difference except it makes a lot nicer noise LOL..
I've been using V power since I bought the car.
did you have to cut any holes at all whilst installing the Typhoon intake? I think there are 2 different ones on ebay, one with description R18 and then another one for 1.8litres. Which one is the correct one for the Honda Civic JDM 1.8L FD?
I didn't cut any holes when installed mine.
here's the product code
K&N Applications for 69-1013TS
everything is essentially bolt on. no holes or anything required.
hi jace, i got my simota pod filter installed yesterday but after driving for a while the check engine light came on!? im wondering wats happening there? should i take it to a dealer and ask them to turn the light off? i know it probably has something to do with the increased air density from the new filter. what should i do?
ur check engine light is on because its a different sort of airflow to stock intake lol... i has simota charger, just disconnect battery and reconnect, should fix problem easy.
as to gruppe m intake for fd2, would it be wise? wouldnt the throttle body be different sizes, hence different intake piping diametre?
if its different size, you will:
1) not even fit it lol
2) probably get a massivly turbulant air flow due to change in diametre, eddy currents etc and prob be worse for the car imo lol
