Nice DIY, does it apply to EK/DC's as well?
Yes , but please check with the location of the ECU connection - it maybe slightly different or a different location to my EG civic.Quote:
Originally Posted by HyperZ
My ABS light stays on and it register fault code 54. What's the error?
The car is 99 Integra Type R Aus Spec
mine says 22 VTEC pressure valve
any ideas?
you have a problem with your VTEC pressure Valve
from the factory it will be plugged into a rubber holder along with the 3 pin DLC. if the last dude to play with it didnt put it back in there then it couls be floating around.
i have an ef8 with a b16a1.. which i presume is OBD0
so do i still pull out the plug and put in a pin to bridge it but instead check the ecu for a light??
edit: just tested it out... made no difference at all compaired to not being bridged.. engine like flashes once and so does the ecu light when key is turned to on.. i guess it is all fine then
you go by the ecu light for fault codes, like you saw, one quick blink, that means there is nothing in there
i have a da9, i was wondering, how do u reset the ECU after ive done the DIY ECU check?
thanks, im about to go do it, wish me luck lol
:confused:
i have NO idea where this green thing is u say where the 2 bit wire thing connects to, i searched and i cant find anyhting even romotly close to it.
where is that in a da9, does anyone know? and what colour are the wires for ours?
Thanks,
if my car has one oxygen sensor and is showing code one id it still applicable?
thanks
sure is
