Correct fuel pressure is 43.5psi with vacuum hose off at idle.
In your case, though it will idle real nice, it will mean you'll need to add fuel with the VAFC up top, which is not effective since you'll likley run out of injector up top anyway.
To start your street tune, ajust the fuel pressure so that the std ecu without effect from the vafc gives you around 12.8:1 AF (0.88 lambda) at 5500~6000rpm.
It'll be a lot easier to tune it for good results from there.
You'll need a walbro high pressure pump too... stock one won't cut it as you'll end up with around 60~65psi fuel pressure.
Set IG timing to 16deg with pins shorted before starting.
