viinnh, what tail lights are those with the clear corners? Is it USDM or EG6 or something? My car will look pretty similar to that soon. What are you lowered on?
installed radiator, radiator upper host, new thermostat, new coolant, type r steering rack, air conditioning, new wheel hub, steering alignment at heasmans...
STILL COULDNT MAKE IT TO THE LAST SOTS AT WAKEFIELD PARK.
****ing fail.
how's your radiator cap? and hoses? is it using coolant? is it leaking coolant?
no need,, just leave radiator cap undone ,, wait till thermostat kicks in and top up coolant if neccessary repeat process if required
yeah redo bleeding procedure,, you can also use the bleed nipple if you don't wana do radiator cap styles,,
park on slope why can't you do even surface?
park on slope equivalent to jacking front of car up lol. I did the last air bleeding on pretty even ground so I just wanna make sure this time.
