i think if u look at my pics on another thread i have started... u should b able to c it
Hey Guys.
couple of quick questions....
What needs to be modified on a 92 to get a 93 front bar on??
Ive bought a pair of aftermarket head lights off of ebay, now problem is cause they're made for usdm tegs they have the amber reflector where our park lights would normally be....
should i open em up n try to mod it with a clear reflector of some sort or just leave and throw in an amber park light globe?
for 92 to 93 front bar look at www.g2ic.com and look for teg tips etc... wen my front bar got cracked the dickhead repairers put a 91 front bar on my 93 DA9 so probz straight bolt! as for the lights, leave it would look different
hey, would there be any noticeable power loss or any problems if i ran a custom 2.25 inch exhaust, headers back with a jdm type r 2.5inch cat?
would it run normal? or should i just try to trade my cat for a 2.25 one?
quick exhaust diagram:
Headers= 2.25inch----Cat=2.5inch----res=2.25inch----twinloop tip=2.25
no modifications for fitting the front bar.. but i think you need to use your 90 bumper support on your 92 front bar.
thanks fellas
its a jdm type r cat? (highflow)? any good?
should be fine. no loss, only minute unreadable gain.
If you need a typer cat i have 1 here if you want it, just the bolts are little rusted so they're tight.
got the same one..doesn't matter it looks gd...leave it on!
u only need to change a pair of metal bracket which bolts onto the chassis...and u can fit the bumper on all dimensions are the same except for the squarish metal bracket...u'll know wot i mean when u take off ur bar...
BTW...ordered the typeR style lip...can't wait!!!!
i think i have those headlights in my shed... im puttin a bodykit on so im using the indicator anyways... but each to there own
that cat should b fine most the time cats r bigger then the exhaust system anyways so u wont have a problem
