Thanks for the help TB, will hve the engine ready mid next week, so hopefully get it back before the xmas holidays, but i highly doubt it -_-"
the old saying is: "haste makes waste"
so just go with he flow ;)
and good luck :)
TB, that website is ****ing ace.
Just read through this whole thread, it's good knowledge for myself. I'm looking to do a B20 setup in the next week or so and I just wanted to know if I went by this list should I be ok? Is there anything else I would need besides an ECU and GB?
B20B8 block
VTEC water pump
B18C timing belt
B20B head gasket
ARP head studs
ARP rod bolts
oil line and fittings
head work (dowels/plug/surface)
piston relief work
PCV system (fittings/hoses/can)
Coolant hoses
VRS gasket kit
b16a head
ITR camshafts (or larger)
ITR valve springs
ITR intake manifold
Larger throttle body
Lightened flywheel
Heavy duty clutch
Adjustable cam gears
Adjustable fuel regulator
Upgraded fuel pump
Oil cooler
(copy and pasted this list from a post on this thread)
Thanks
wow, that is a pretty good list!
but you also need to check things like the condition of the driveshafts, i usually get them reconditioned at the same time if the boots are starting to crack...
also check the engine mounts...
Hey guys, is it alright to run 2 sanwich plates?
I got the vtec conversion sandwich and would like to add another for an oil cooler....
