Quote:
Out of interest though, since I have a D16Y1 and a B16A, how would you plan to make approximately 90kw atw on a SOHC D, assuming that the B16A2 would make approximately that much power in stock form? Full head build + bolt-ons?
When i said this :
My point was that whether I spent $3000 on a D, or $3000 on a B16A2 swap, I'd end up with the same power. 100fwkw can be made with a D for that amount of money, both with and without turbo. cheaper if you remove labour costs (for those that can do some of it themselves)Quote:
I can spend less than what it costs for a swap and be making the same power as a stock b16a2, the only real difference is that i have lower power ceiling than the B.
The scarceness of built D's in australia seems to give people the impression that its mightily expensive to build one. It's not. The parts you need just happen to be less common, thus you need to look a bit harder.
You won't get the bang for buck that you would get with a B, but again, for me, its about seeing what I can do with it before moving on.
One thing that I think most people can relate to, is that $5000 is a lot of money. As stated previously, I'd rather not blow $5000 in one hit and then have nothing left.Quote:
Furthermore, for $5000 you'd probably be looking at a B18C2 conversion which is stock 125kw, has better gear ratios than a D, and more torque to boot. Or you could do a B16A2 with I/H/E.
If slowly modding a D, bit by bit, makes it affordable for me to build an engine NOW, then I'll do it. I'm sure beeza probably feels the same way - i mean hes building the y7 or a y4 i think? + its auto! All to satisfy the need to know what it can do, how far he can take it while its affordable, rather than having to wait and save up.
Look at it like this, if you want to go with the usual stuff like i/h/e, cam, ecu, tune
Buying an n/a D = $300 for the motor, + $3k tops in mods. Add another $2k if you add turbo
Total cost = $3300-$5300
Buying a b16/18 = $2500 - $4800 for motor, + $4k in mods, if not more.
Total cost = $6500 - $8800
Being affordable at present, and having to save for 6-12 months and living off fck all afterwards just so happens to be a difference that acts as a determining factor for some.
Now...
i/h/e + cam + ecu/tune + high comp pistons.Quote:
In total, all that is costing me $2300 (give or take). Surprisingly the majority of it in i/h/e, admittedly im not sure how much will be spent in tuning. As little as possible im hoping.
Keep an eye on my build thread for something more accurate as time goes by
I think JasonGilholme said it earlier, having fun doesnt mean being the fastest...I know im enjoying what I'm doing, and I'm learning alot in the process because it requires a bit more research into how things work, rather just reading through a B swap faq.
Dougie, sorry for replying to your post with a novel lol.
