Fan has blue and red wires, my plug from the OEM fan has black wire and a blue one with a black stripe down the centre. I soldered the blue to the blue and black to the red.
just look at the fins and see if it's spinning the right way..
Couldn't tell which direction. Just rewired it now, going for a test run. So far so good, lots quieter than before.
if it was using water it would be, but seems alright
Took out the intake resonator today, but now my fender lining is all ****ed up! Was bending it out of the way to get to screws and shit. Anyone know how to fix this? There's no screws that holds that part in
http://img831.imageshack.us/img831/5...1120173950.jpg
http://img24.imageshack.us/img24/537...1120173940.jpg
that part just get tucked in. all you need to do is push it back behind the bumper... no screw needed.
I tried tucking it in for ages, stubborn piece of shit just won't tuck :(
pull the bumper outwards. then bend the liner. push it back in. or... use a flathead screw driver lever it in. make sure you have a cloth on the head so it doesnt scratch.
I found that there's a way to do it for mine. Try inserting the top corner first cause its slightly more flexible. Once you get an edge in, the rest should be easy to push in. Don't try to push the entire edge in at once though.
how much kws did you gan removing it?
**** it just take it out. i did it to my left side because it started scraping after a drive through the north side hills.
