no - you are meant to change the headbolts, not the mainbolts...
i dont think there is a strong reason to change the mainstuds on a non-boosted B20VTEC.
u mean the head studs? i found a link that shows exactly what you were talking about re-threading the main studs using the ARP fasteners.
can i use B16A main bolts or are they different size/thread?
no, i SAID: "you are meant to change the headbolts, not the mainbolts..."
FYI - Hondas are build with headBOLTS and mainBOLTS
you MUST change the B20B headBOLTS to either B18C headBOLTS or aftermarket headSTUDS...
you can do what ever you like :)Quote:
but i have already answered your question if you bothered to read my posts...
thanks for clearing it up.
Well normally people dont for a b20vtec build.
Anyway, my new oil pump looks likt the one on the right, and my old oil pump looks like the one on top left.
Timing belt cover cant fit, anyone knows what cars run this timing belt cover that would fit?
http://www.tamparacing.com/forums/at...ns-oilpump.jpg
Thanks,
Leon
the one on the right looks to be a B16A oil pump, the left might be B18C.
everyone running with non standard bottom end, what compression do you guys have?
