Clay the motor to check clearance
take it to PM or you will be banned.
so far wenever i say to someone im building a b20 up all they say is there so unreliable n it will blow....how many people have had problems with there builds? and is this just a assumption because the motor was never made for vtec?
If you build it properly eg. Apart from decent pistons and rods use 5 cap girdle, decent dampner like fluidamper, balance everything and don't rev past 8,500rpm should be ok.
All comes down to the quality of the build and not reving it past 8,500rpm.
http://www.jhpusa.com/store/pc/catal...rdamper6_d.jpg
ATI Super Damper standard harmonic balancers are specifically designed for high-rpm engines. Their proven elastomer is designed and tuned to eliminate harmful crankshaft harmonics that cause parasitic horsepower loss. They are actually two dampers in one--a 4 in. diameter inner damper and a 6 3/8 in., 7 in., or 8 in. diameter outer damper in two shells that bolt to the crank hub. These dampers are engineered to all but eliminate worn parts and timing problems. They're tunable in the field, rebuildable, and extremely efficient at all rpm.
do we really need it?
It's good insurance.
Yup, following Helms... maybe I should try the clothes hanger technique... Also, it may be tight enough, im not sure...
May I ask, is it strange to have a reading of 300psi on all 4 cylinders? I poured oil into the combustion chamber as I heard it would help seal the rings, and cranked the car without plugs for awhile, maybe I poured too much?
