Must have missed it,Quote:
Originally Posted by vupham
I try & answer as many as I can per day.
http://www.ozhonda.com/forum/showthread.php?t=13667
Hi Adrian
How is your Type S project progressing?
regards'
Ryan
Adrian,
Can you add some information on your recomendations fro going down the forced induction path, whether it be Supercharging or turbocharging :)
Cheers
great info....good work adrian....cheers mate...
Medium budget – Stop @ ECU
#1 – Lightweight flywheel
#2 – Heavy duty clutch
#3 – Lower final drive
#4 – Intake – CAI's deliver superior results.
#5 – Header + S2000 cat + cat-back system
#6 – Spec C camshafts / valve springs/ 0.3mm head gasket (Compression up from 11.0:1 to 11.4:1 / Titanium retainers / ported head / JDM intake manifold / ECU / dyno tuning / heavy duty engine mounts.
Power output: 154 ~160kw @ wheels (Dyno dynamics – shootout)
8800rpm rev limit
or
Low budget – never going to get an ECU
#2 – Heavy-duty clutch
#4 – Intake - CAI's deliver superior results.(Eg: INJEN / AEM / GruppeM)
#5 – Header + S2000 cat + cat-back system (60mm minimum)
#6 – Spec A2 camshafts / valve springs / head gasket 0.3mm
Power output: 126 ~128kw @ wheels (Dyno dynamics- shootout)
NB: Add K100 ECU for 144~146kw
For even more power, Spec A3 or Spec C camshafts can be swapped in.
just wondering wats the costs for these mods well roughly neway??
Hey Adrian,
Could you tell us quickly about the benefits/drawbacks of Metal Matrix CATs as compared to S2000 CATs? In an earlier post you rave about S2000 CATs and later on you mention that Metal Matrix CATs are recommended for best performance. I'm confused :(
Thanks!!
no cat is better :D
whats does it mean by
"NB: Spec C camshafts, VTC function is retained."
Adrian - is the S2k cat a perfect fit onto the DC5R? What about the sensors? (If I remember correctly the DC5R has 2 on the CAT?)
Also any reason why u recommend a s2k cat over an after market hi-flo cat?
thx
guys what do you all think of the APEXi Super VAFC II does it actually make a
decent improvement or is it a waste of time and money???
Sorry guys, im composing responses for you guys due to Adrian been so flat out. My apologies, but im pretty flat out atm myself, will get onto this or let adrian know about these questions as soon as possible.
If your in Sydney and require urgent responses, please call Adrian at the workshop.
If your in Melbourne you can contact myself.
Regards.
hey man, i think this was covered in one of the thread in Integra's section. have a look, mayb is 2nd or 3rd page. but IS there....Quote:
Originally Posted by XXX_R
however i remember all of the guys saying jz that VAFC II doesnt do much if jz install it without other components and tuning.. imagine that jz a remote control, u need to all other speakers and mixers and the screen to workin along with. :)
cheers :thumbsup:
