5x114.3 between +45-+55 offset & lugnuts should be M12x1.5 <-- confirm with someone else but thats what i know.
cheers, I think I can get away with 42 offset because its only 7 inch wide. Hopefully no probs when it comes to lowering
42 offset is fine, difference to 45 is so little.
M12x1.5 :thumbsup:
Thanks!
Sorry to revive an old thread guys, just considering getting some new rims and i want to make sure i get the right size etc.
Rim size - 5x114.3 / 17x7J with +45 Offset
Tyres - 225/45/17
Would that be suitable to run on the euro? I'm sorry, very noob with all this technical stuff
thats fine, thats just like stock 17"s but with a lower offset which is even better :thumbsup:
thanks for that guys =) will post up pics when i get them
Would that 20mm affect the speedo reading much? reading higher or lower?
No, the offset will not change your speedo reading whatsoever. It's the overall diameter of your tyres that will change the speedo reading (as in if you change your rims and tyres and doesn't follow the oem spec anymore).
the 20mm increase in track he's referring to means that the distance between left and right tyres increased by 20mm over standard oem spec.
ahh ok, thanks for clearing that up euro77. I'm going from the stock 16" to 17" but, so i'm guessing theres going to be a change
