This write up is missing something...
When do you put the new fluid in?
confused..
confused..
theres your answer:pQuote:
7. As you are doing this, keep topping up the fluid in the master cylinder reservoir. You MUST make sure that the level in the reservoir does not drop below the low mark or else air will enter the system. This is a big NO NO!
So you pour the new one into the old one?.. wouldn't they just mix or does it sit on top?..
well what you can do is suck as much old fluid out of the reservoir first then fill it up with new fluid before you start pumping
makes the job faster if you don't want to work through the old fluid
AH,gotcha,cheers Vin!!
Is it OK to use Castrol Dot 4 Brake fluid in my 96EK1 Civic?
I'm pretty sure it is but...
i do, i use the castrol response super dot 4, and its fine, even when tracking
Thanks mate,I thought so but someone put the ol'
"You should only use genuine honda fluids in your Honda" line.
I was like - "BS"
Thanks Aaron!!
hehe,sa-weet! :)
when pumping the brakes, do you have the cap on the reservoir?
