A-man, would love to see a build thread
Yeah me also
If you are serious about doing a J-swap, have a chat to Derek at All in Fabrication (https://www.facebook.com/AllInFab) over in the States. He does radiator & a/c condensor tuck kits for B/H/K series, so I don't see why he wouldn't be able to do it for a J series. All you will need then is custom A/C high & low pressure lines
if j swap is legal for road use , i ll do it to my Eg like how i done h2b bcoz i like doing something different than everyone else
I would be guessing that it will be on the difficult side to get a J series engineered for road use, unless you went all out on the build & upgraded everything to above par standards
an update on mine.
I have it running, I used the j series v2 mount kit to make the engine sit higher in the bay because ground clearance was non existent. I wired it up, good thing about the j series is its very similar to a k series and only requires a handful of wires to get it up and running. (being that mine is an auto remember).
I had to redesign the j series shifter. I put the j series shifter cable with the eg shifter box then modified and welded the cable at the correct length.
radiator is in (just like a k swap cut the mounts off relocate to the other side reweld).
unfortunately when you move the engine higher in the bay the headlight fowls on the alternator. So i need to relocate the alternator or leave one headlight out?
I have been a little busy with moving house, other projects and being lazy i guess with completing this swap. I need to get my ass into gear and get it done! the next part is just to clean up the wiring, put the dash and ecu away make the bonnet close. and test drive i guess. I have a bigger throttlebody and I want to spin the intake manifold 180 degrees too.
go and drive a vr6, heavy over the front, handles like shit, impossible to service
j series is just stupid when you can get plenty out of a b,h or k...
If you wanting to see a J-swap have a watch of this guy in Aus that has a video blog of it.
Well worth checking out his other videos also
V6 Civic EG Muscle Hatch - phase III - 3 litres
http://www.youtube.com/watch?v=SkgdY...dT6CIebxpcaeAE
I think he is on here somewhere?
There was a similar build on NZ Honda's
