Originally Posted by
MM89
well if cylinder thickness is 2mm for oem and you plan to drill the inner diameter out from 10mm to 12mm, you'll be left with 1mm wall thickness.
strength would be weaker regardless. i'm guessing it'll probably deform if you squeeze the cylinder back into the bush. not sure if that's gonna be a big issue, but i personally don't like any part failing on my car, especially if its caused by my error.
what you need in the correct dimensions should be available at a bolt and nut store or hardware shop.
Spoon has springs that fit to oem style shocks. Koni also makes springs to fit. JIC does. There are many out there. The question is, can they hold their actual spring rate over time and what is the variance in claimed and measured spring rate. Eibach and H&R are very well known. I'm happy with the eibach springs, but who's to say there isn't better something out there. I simply paid the price the I wanted to pay and got the product that I expected to get.Hypercoil is apparently as good as it gets. But pricing will follow suite.
