I've used both BP ultimate and V-power and i get better mileage on vpower. Usually get 200-220 when needle hits halfway. BP hits at 170ish
Hey man, I have the same prob, full tank with 45 liters but fuel gauge looks pretty empty after 350 kms but when I filled in petrol, it only takes 25 liters to fill it up...
ei guys hoping some1 can help me with a slightly unrelated topic. my car is on 200k milage and it burns oil pretty quickly. every 2-3k the oil dipstick reads low and i keep topping up till about 6k then i service it. just wondering if any1 knows about the additive that is meant to be aded to the oil which is meant to make it a bit thicker and clean out the inside a little. do those products actually work?
hey man, have you checked your engine internals? like oil control rings and such, im not very good at this but i do recommend u check it at your local mechanic.. cant help much but gd luck mate
There are a number of ways you can burn oil. Your piston rings could be worn, letting some slip into the combustion chamber and getting burnt or it going through your pcv valve into your intake manifold. You could also be leaking it from a number of places such as oil filter seal or main seals. Get someone to look at it.
found your problem yet mugen euro?
Anyway guys a update: ive been running V-power (shell 98) for 2 weeks now and im averageing about 430km outa 55 litters and i only tooke the revs passed 5k about 5- 10 times every week, and thats only in first or second. Generaly im shifting around 2.8-3.2k revs
soo not lookin great
take it to a shop or somethin and get everything checked? or have you already done that
