Mines super quiet and is 3"
howd you go with the install man
It's all on, belts done, Aftercooler done, fluids filled etc.
Raining pretty hard here today so I stopped at 2.
All that's left for tomorrow is to connect fuel line, power steering hose and re-terminate the wires for pump, water temp sender.
Been sitting inside all arvo working on my ecu maps.
Woa your too smart for your own good.
Wish i could do my maps
Well cars mechanically sound, zero issues with the kit/install.
Actually easier to do than a header swap.
Been working on the tune today, started off by setting a "over boost cutoff" at 2psi.
Drove around and data logged, came home and adjusted the fuel/ignition tables across 0-40deg cam advance to remove any high arse AF/R spikes (at one point I got 16.4:1!!!!! Super lean)
Partial throttle is now safe, idle is 14.0:1, cruise at light throttle is 13.0:1
Tomorrow I'll slowly increase my boost cut a point at a time and tune each point until I get to the 10psi boost level @7500rpm.
Have been surprised how easy K-pro is to tune on the street alone. Every tuner in Perth backs away from Hondata for some reason. (their homo)
See how it goes!
Are you just going to tune it yourself?
haha simon when you open up a hondata tuning shop in perth let us know :P
A little, Pro tuner is due in Perth early March.
All I'm trying to do is make it very safe to drive until then.
When you buy Kpro/Ktuned I'll install it for you ;)
Cant you just work of base maps and adust it from there.
My k-tuned k-pro should be ready soon since they're reflashing the core atm.
Shmivic, maybe you can drive over to Sydney and have your car tuned, and while you're here you can also install my k-pro while you're here? :P hehe
