i dont want turbo want to try NA
i dont want to spend that much i see you got all brand new parts and extra bits i want just a basic budget setup im looking to try and do it
for between 5 to 7gs max i already have the brakes and sussy side done
come on guys give me a price on a basic k24 setup without labour
Your lookin about 7-9k just on basic parts needed to get going.
These are using oem parts and no upgrades to clutch/flywheel or injectors etc.
Best bet would be buy a k24 motor/gbox/ecu/shifter cable & box and engine charge harness. Easy $1.5-2k
Then buy yourself the stage 3 ktuned kswap kit 3-5k.
Then u will need your exhaust welded up to meet with the headers to cat. $150-250.
If u dont want to use oem ecu, then kpro v3 + tune = $1.8k
Plus new belts, oil, coolant, spark plugs $250
Plus other misc fabrication $300
Engine Mounts $500-600. ( this may vary depending which mounts u buy as additional parts will be required. I.e dc/eg subframe and s/rack, fsb etc)
Ac/ps delete kit $300+
crv bracket $100
Optional
+ engineers cert $800-1k if ur in syd
+ bigger rotors & better pads $400
Then install it yourself.
These are just approx figures prices would vary.
The ktune kswap kits should have majority of parts u will need, driveshafts, harnesses, fuel kit, rad hoses and sensors, intake and headers
Hope these figures have helped out abit.
Benson has given you a price already. If you look around real hard, and if you have some luck you can probably knock ~$1k off that price by sourcing everything yourself and substituting some of the 'brand name' parts with used oem.
At the end of the day, it is still a very expensive swap.
Question about the IACV for K20. Mine has been playing up lately specially since the weekend. Idle is screwed.
What tool if any, have any of you used to unscrew the 5 sided star screws that hold the electrical plug to the actual valve?
Went to repco, supercheap and sydney tools but did not find anything.
Sorry to whinge.
But can the spam posts in here be deleted. (including this one)
I'd hate for it to ruin what is an informative thread.
