really? thats really good to know! thanks! esp. knowing you bein nicer to enviro too! and thanks, i'm happy to have learnt some more! cheers!Quote:
Originally Posted by iamhappy46
MoD
MoD
I did mine today! it gain a bit more power and it is very obviously when hit vtec...the car go harder!
very happy of it !!
this also means you get more energy...
if the rate of consumption is the same (ie WOT), and the petrol contains more energy per volume, then you get more pwer... :)
Correct.
i just found some good info about this for d-series... (how to do)
http://www.sohchonda.com/ipw-web/bul...ndex.php?pid=5
i advanced my timing last week end.. made a HUGE difference.. considering it was set at 14degrees hehe
i went to 18deg and now the car screams
i think i had really noticeable gains coz i was drivng my car around retarded for the last 10 months..
on the track i managed to shave approx 3.5 secs off my 0-160 time (from 24 secs to about 20.5) and about 0.5 secs off my 0-100 (from low 8's to high 7's)
so many pros and cons....but a good read i must say...
so on a dc2r is the standard timing at 16 degress? can someone please confirm?
and if so i advance the timing...what should i advance it to?? 18 degress? (i am running on 98 RON)
thanks
oh and my aim is top end power..
Check in your manual or on the plaquard on the bonnet.Quote:
Originally Posted by Astro
ok say it is 16 degress...should i advance it til and only 18 degress?
How will u know when it is 18 degrees?
http://hondata.com/dynocivicsi.html
interesting read here
there is a huge difference between a tuned stock b16a and untuned stock b16a
the 3 timing marks are 14,16,18deg respectively from memory
