G AE82: lOOOl heheh :) well that sounds fair id say :p ... All the best of luck bro ;)
Looking very good *thumbs up*
Its a bit of a trek for you guys now that GRP are out at Brendale??
10krpm: Yeah it is a bit of a drive but I'm not complaining :)
These should be the last of the pics for a few weeks. Once the ancilleries are all sorted everything will be taken out and the gearbox will be fitted with a heavy duty clutch, engine bay will be resprayed and axles should arrive from the states (BLOODY DRIVESHAFTS!!!).
p.s. JIM..will talk to you soon
http://i22.photobucket.com/albums/b3...h_IMG_0845.jpg
http://i22.photobucket.com/albums/b3...h_IMG_0839.jpg
lookin good!!!
awesome stuff there man! :thumbsup: :thumbsup: :thumbsup:Quote:
Originally Posted by G AE82
if you wanted a trick, the water pipe connection on the front of the motor can be filed and then turned 120 degrees around so you can mount the radiator on the other side of the car and then run the filter straigt down into the bumper.
Thanks for the info Non Vtec. It's certainly good to know. I'll definately think about that option.
The car originally had a b16a and the inlet manifold was very close to the firewall. We had problems as the engine twisted (broke) the rear mount frequently. The dents are a result of this and the numerous times the engine had to come out to fix the problem.
Hella impressive...look forward to seeing more of this
Hey jase, its miki here
Did you get to take the civic out for a drive yet? Should be almost done right?
Check out this ek with k20...good parts suppliers...
http://www.jdm-theory.com/
Hey Miki.. everything is out of the engine bay at the moment as it is in the process of being resprayed (firewall has been smoothed and painted with primer so far). Only parts we are waiting on now is Hondata (which should arrive today) and fabrication of the exhaust! Don't worry once it's ready I'll take you for a spin! :D
