Just say if I don't reset it...wouldn't the computer automatically recognise the change? I drive a 1998 vehicle so it should be smart enough, right? If I don't reset it, doesn't harm the car at all besides the slight urge to drink a bit more petrol?
What about just take the battery cable out, isn't that a lot easy.
not quite as easy as popping a fuse in & out.Quote:
Originally Posted by kimo
yeah, if you like resetting all the radio security code, station presets channels and the clock.Quote:
its much easer to do it through the fuse. only disconect the batt if your not having any luck finding the corect fuse.
thats awsome idea :)
Easy....
but... if you got an alarm wired with sensors and shit in your engine bay... damn, reset the battery will kill your ear drums.
Easiest way I find, is to remove the connector plugs from the ECU.
This will remove the constant power source and all RAM stored parameters in the ECU will be cleared.
Correct! :thumbsup:Quote:
Originally Posted by ProECU
This method will also remove any viruses you have contracted from the internal flux processor. :)
please lets all have a big ozhonda hug and perhaps we can make out. oi who cares, just pull the plug, and take off the battery cables.. what ever! its all good
read through everypage i jus had a look under the bonnet of my ek4
which fuse is the ecu i cant figure it out SORRY FOR THE NOOBNESS :$
so can u do all this in the morning when the engine is still cold, or do u have to have warmed up the engine ? coz the motor tends to rev high during idol wen its cold, will this affect the outcome?
yeah i do have the same Q as toy civic
