lol i just notice i havn't recieved one rep point for this thread.. lol guess the mods don't like carputers lmao.. arh well..
i'm just going to go take some more pics then hehe
Mods to roadrunner crystalblue skin:
change loading screen to steel-honda
change background to have honda logo
changed both fonts to megadeth.
PC loading
http://a935.ac-images.myspacecdn.com...ff67b8bab6.jpg
XP loading
http://a933.ac-images.myspacecdn.com...156e0e0d4c.jpg
Roadrunner loading
http://a369.ac-images.myspacecdn.com...c64269dd50.jpg
Roadrunner
http://a740.ac-images.myspacecdn.com...97ab9d8d73.jpg
http://a858.ac-images.myspacecdn.com...6996f95a39.jpg
http://a473.ac-images.myspacecdn.com...789be64d68.jpg
Going to be centre speaker for surround sound
http://a427.ac-images.myspacecdn.com...e0685e6ab2.jpg
Your set up is looking great man!
You mentioned you are going to use a center speaker for your surround sound. Where would you put this, I don't think I've ever heard of having a center speaker in a car! Such a cool idea. I'm guessing it will be mounted under your PC screen?
I'm in the process of installing a car PC as well and I'm also using Jaycar amps. I will post pics once it is done.
Good work and gratz on the car PC, I'm very impressed.
btw I don't think I've ever seen anybody change their avatar as many times as you have heh.
will go pretty close to where it is in the pic, there is enough room to make up a mount and fit it in the cavity beind where it is in the pic, it only a 4" but most front centers are small even in home theater, normally just voices etc in movies. watched a movie tonight in car (while parked), and had some voices missing putting it down to not having front center connected, will check tommorow but if it was then def need front center.
Edit: I'm running full 5.1 sound.. but waiting on sub to arrive (paid for) and gotta get energetic to make mount for center front.
Good luck with carputer good to see more people doing it, get a few weird looks when people see it, and few others go fark build me one.. but loving it so far..
normally don't change my avatar that often, but when I do i can't decide and change it a few times lol.. didn't think anyone noticed hehe nice work..
looking forward to seeing your pics :).. any progress shots?
going for a sub install similar to this
http://www.earthquakesound.com/IMAGE...y/chuck/c4.jpg
nice man
very nice
do i see girls gone wild on ur playlist ? :)
That sub set up is very similar to mine:
http://img442.imageshack.us/img442/5...5903xm0.th.jpg
thanks for the pic.. looks like a really nice install, was trying to figure out if i will go carpet finish of not.. but that looks sweet. think i will go that way. wanted to go sealed as well.
Have paid for and waiting to receive 2x (should be here Friday)
12" Subs
MODEL: TremorX-124 1250 watts
# Stitched leads
# Spring loaded speaker connections
# Anti wobble cone construction
# TCT Technology (Turbine Cooled Transducer) for high effeciency output.
# Military grade single 4-Ohm voice coil
Also 1x
Mono Block
PH2000W/D1.1
Number of channels: 1/Mono
Class: "D"
Max Power Output: 1400 Watts
Power 1-Ohm: 1 x 100 Watts
Power 2-Ohm Bridged: 1 x 700 Watts
Power 4-Ohm Stereo: 1 x 450
Damping Factor: >800
Cross Over Slopes: 24dB/OCT
THD: >0.016
SNR: 104dB
Speaker Connections: 8-Gauge
Power/Ground Connections: 4-Gauge
Input Types: Low Level RCA Inputs
Dimensions (HxWxD): 2.375" x 10.125" x 12 "
craazy lotsa respect dray
mind giving us a breakdown of the cost of ur project? lol
Hey Dray,
If you are thinking of having your cones facing into the cabin, have you thought of putting perspex on the back of the sub box to show off your magnets? You will have to make sure the inside of you sub box is nice and clean though. Put some tinted perspex so you can only see inside when the lights are on. Wouldn't be that expensive to make, but would take alot of time. I have seen some photos of somebody in Melb doing it.
I'm still in the process of going through my audio set up. I'm getting a bit of hiss through either my LOC or RCAs so I'm trying to figure that out this weekend.
Also, if you want a 1 Farad Precision Response capacitor, I might know where you can get the old ones that will match your amps. I'll post a pic of mine soon.
