thanks aaron i noticed taht it was thicker too and was just about to file it when i got lucky with the above combo.
mine didn't have this problem. perfect fit. but there is a plastic cap on the gear stick. I did remove the plastic cap. then perfect. the leather boot just too long for the SS.
Which provides a shorter throw, the mugen ss or the comptech one?
how close does the gear knob get to the hand brake when its in reverse with the mugen short shifter ?
2 cm between ?
yes, still can do the reverse and release hand brake. about 3cm gap. I might have a fat hands compare the others. hehehee.. sometime my tumb hit the hand brake when shifting to reverse.
This is a bit off topic, but is there any way to remove just the shifter stick from the assembly?
I want the shift knob to sit about an inch lower. I went to a machinist guy at uni and he told me I had to remove the shifter stick.
In other words, how do I do this? ^^^
Cheers
Thanks Aaronng!
I will do that this weekend!
If I could give u rep points I would. :D
Heres a pic of mine installed with AP2 gear knob.
http://i184.photobucket.com/albums/x.../IMG_97321.jpg
