i have a EF8 b16a1..
error 22 ..
is this also vtec pressue switch or valve?
this would stop vtec kicking in too?
error 22 ..
can you do this test on a s2k?
if so, how?
same
just jumper the blue 2 pin femail connector
read the flashes on the dash
so take off the left hand side kick panel and it should be threre somewhere?
same colour wires?
its actually in the drivers side, under the dash inline with the clutch pedal
the connector sits in the green holder that holds the 2 pin SCS connector and the 3 pin DLC connector
you want the 2 pin female connector with brown wires
thank you very much again, mr. you are the shiznit
lol.
hey ecu-man.i have a 94 integra vti-r.i wanted 2 ask.where would my blue 2 pin femail connector be in my car and w0ould the codes uve posed apply 2 my integra??
Looks exactly same as ben shows in 1st post(green holder with 2 blue plugs),but i think its located more towards firewall above passenger foot well.Quote:
Originally Posted by BoneZ
Edit:codes already posted by ben,yes they r the same
hey fanks 4 all dah help CRXer...appreciate it...
yeah Bonez what CRXer said.
Pasangers kick Pannel in foot well
Excuse me everybody .......
Does it works for JDM DC2 96 Spec ? and how do we define the code from the blips ?
yes its the same
long flashes indicate tens
short flashes indicate units
so for eg
two long and 3 short together is code 23
two long on there own is code 20
two short on there own is code 2
there is a pause between codes
