On what motor?
b18c SiR motor
When you get a boost controller it will fix this. It will allow you to bring the boost on earlier.
Before EBC full boost didn't hit till close to 5000RPM's
http://www.doubledynasystems.com/Car...05-05-2008.jpg
EBC Installed now full boost kicks in a bit before 4500RPM's
http://www.doubledynasystems.com/Car...06-12-2008.jpg
And that's with my crap bushed turbo..
Your ball bearing turbo should spool even faster...
Post some dyno's?
Yep get a boost controiler.
I have same setup, GT28RS on a jap B18C running Autronic SM4 with optional boost control solenoid.
I get my full 8psi at 2700rpm, not kidding!
Currently got 2.5" mandrel from turbo to high flow cat, and 2.25" crappy crush bent from then on.
Going to upgrade soon.
ive got 3 inch from the dump pipe all the way back to an apexi n1 muffler.
i will be getting Eboost2 i think shortly, but then you have to get a full retune so it may be a little while...
how much power r u making mooshie?
See my thread- 'another DA9 turbo'. 157 at the wheels currently.
with my eboost my car get full boost at about 3.5k, b16 with GT28R@162kwATW.
That's why i told luke earlier on to get one :)
lukezen do you know anyone who has used a td04 or td05 to do this d turbo thing, everyone talking about it and i got a d series motor here, might give it a go ?~just want relaible first with td04 or 05 with stock internal~possible?. i read heaps of shiet on us forum~but they are changing pistons to low comp, however the d series motor i have is not vtec, ordinary single cam.
its pretty small bro, same as a wrx 99 model *not sti. i got one here, but i dunno i just read through this thread and it maybe a better idea to get a greddy kit, but economy is shit you know.
pretty good thread.
luke pretty sure yours is a TD04, its about a T25 equivalent
ok, lol well i will see what else is required, might just get GReddy kit, instead of hassling around with the shit i got.
yer not expecting it to be hardout, just doing for fun around~i would rather NA, but i wanna give this turbo honda a go~.
so ecu comes with the kit or is add on, ?
i think lylse (sexc86) is running a td04/05 on his d series turbo. send him a PM. should be able to help you out.
yer i was talking to him on another thread lol~intresting.
not 100% sure but something like that,
Not that good with the td range
Well one motor blown :(
Thrown a rod on the dyno today
thats unfortunate man... but u knew it would happen running such high boost
at least a d series is a cheap fix
Thats interesting..... Were they stock rods???
I was researching the possibility of a turbo upgrade for my D and most of what i found was that the rods had an almost power barrier.....
At 220 hp/157kw, the rods were said to break.... and u made 224hp/160kw and they broke....
Are you going for forged rods next time round???
damn 160kw? not too bad ey...
what mph were you gettin that drag night?
thats a shame :(
what would a b-series throw rods at?
Guys
She was not tuned for 160wkw!!! that's what DOHC VTec Turbos make with stock internals
She was tuned at 137kw 11psi
That only happened on the dyno after a problem somewhere that caused a big boost spike..
I’m yet to working what exactly caused this but once I get my car back I’ll take a closer look…
Its more than likely at vac hose has come loose…
And yeas the weakest part of the D’s is there tiny little con rods hahah and yes completely stock
there are quite a few B series pushing 200kwatw on stock internals.
B series bottom ends are alot tougher
i'm still suprised the eboost didn't catch it
Well guys
That in fact is what's happened..
Just got my car back and the e-boosts to Turbo hose has blown off....
o well guess it wasn't the tune then
now u just need bigger turbo!
No the install :o
Anyway all good
He's the bugger
http://www.scruffie.com/luke/car/hose1.jpg
Other hoses
http://www.scruffie.com/luke/car/hose2.jpg
e-boost
http://www.scruffie.com/luke/car/hose3.jpg
mate this is what the rear side of the t28 looks like
[IMG]http://i.ebayimg.com/21/!BKS!vQQ!Wk~$(KGrH****jIEjlLmYd13BJZHlIW9,w~~_1.JP G[/IMG]
yeah i can give that over cos its only for that particular turbo
Larger ones don't have that
Nice photo :o
Just before
http://www.no-limits-performance.com..._img_4682.jpeg
Right before pop
http://www.scruffie.com/luke/car/on_dyno_one.jpg
Few bits and pieces out of the inside of my motor :(
After
http://www.no-limits-performance.com..._img_4685.jpeg
sweet EG! lovin the front bar
what rims are they?
he went for a dyno run for some reason
no offence but is that a legal dyno place?
the ones i been to are way more "professional"
looks a bit ghetto to me
u need to get out more!
:p
It was my local can club dyno day
hey luke, who did the install? DIY?
well it was ur fav shop of course
I cant find any reference in the thread anymore? I would apprecite confirmation.
yeh luke really diggin your front bar mate
ahhhh kk my mistake
So ive installed an eboost on a greddy kit before and i know exactly why that hose popped off.
Has he explained to you how he cut corners, and as a direct result your engine is in peices? If he hasnt, i'll explain it to the whole of ozhonda tomorrow. A nice little appreciation thread for the consistantly outstanding professionalism shown this shop.
Oh, and let the blame game begin.
lol can't wait
I would like to know why it came off...
It all looked tight to me
Isnt it interesting that every other line he installed doesnt have a cable tie. Must of been some uncertainty at the time... Taking the shortcut... But the shortcut failed. For a few reasons.
There is a reason why greddy has a pre-bent silicon hose on the OEM turbo/wastegate setup.
Just goes to show you should never use cable ties anywhere on your car. Unless your useing them to.... "Tie Cables" !
might run one of these d turbos on a daily car lol~ just for turbo tunning fun.
is it possible for an emanage to lose its settings, say if the batter y is taken out for a while .. etc?
nope e manage has flash memory EPROM or someshit
cause my cars makin knocking sounds like its untuned....
a honda or something else ?
you might have a airleak. have you done anything new to the car since last tune
hmm nah nothin at all,
airleak as in cooler piping?
ye its a honda
yer could be~lol i dont know much about hondas man. but from other cars i know could be your airflow sensor has been damaged or is dirty.
