depends how low you are. Though the 8.5, id say run 215 instead. Will need to roll the fronts more so its like a bit of a pull/flare if your tucking tire or plan to and thats with a front camber kit at about -2.2
Rears on 225 is fine, remove the rear bumper tab and relocate it if you want and bit of negative camber ( -2 or more ) and you will be right.
