what good ep3 info sources are there? atm i got ephatch.com forums? any other Uk forums?
http://type-r-owners.co.uk/forums/
http://civictype-r.co.uk/forum/
^^ these two are the biggest and best by far
Hi everyone, anyone here with an ep3r running buddyclub racing spec coilovers? I got mine installed but my left front wheel has extremely bad toe out which is to the point of being un-drivable, my mech says the coilover might not even be for my car as the suspension geometry changed drastically which it shouldnt have when changing to specific coilovers for a model, even though my front right wheel is straight as an arrow and the rears fit... any help is greatly appreciated.
There's a guy who imports EP3Rs from japan and sticks them up on Firesport.com
not only guy, a few guys but
my question is, was it the same case with you when you installed these coilovers on your ep3r? as in the front left coilover installed showed massive toe out angle which rendered the car undrivable, and adjusting the toe angle back to alignment would be dangerous as the adjusting the toe that far to be aligned would leave little thread connected to the tie rods which can potentially disconnect during driving.
My mech actually thinks these coilovers i bought arent even for the ep3r as the suspension geometry went overly wonky after installation.
thanks for your help
hey guys do you know where i can get part number for driver side rubber moulding?(the whole frame rubber moulding not the window sill rubber garnish) ----(i will take a pic tomorow and upload here to be more clear tomorrow)
edit: i think its called door sash trim or rubber dam? the moulding that runs alongside the door pillars etc.
cheers
when the coilovers were put it on it was pretty much like plug and play, had to adjust the tie rod ends abit to reach the coilovers but thats about it. when my car got defected i took them off to put the stock suspension on and changed it over again after the defect was gone and it was like normal.
took a ride in my mates ep3 with gruppe M
and i must say it is TOTALLY different compared to my mugen...
i want one...
