It might show it that it gain @ WOT, but it'll lose a considerable amount of power @ 50 % throttle. Where do you spend most of your time driving i/e street car? AT WOT or cruising say with 10-40%? throttle?
argh
torn between going b20 or stick with my b18 and do cams and 4.9 fd
benson, how did you go about making 150kw? how much would i realistically have to spend to get there (considering a workshop will be doing it all)
If you want to keep it reasonable, you have to DIY.
i fingered it'd be about 10k
edit- wow thats with no labor costs!
Sell your B series off and add 5k ontop and get a k24 in there :)
50% throttle ? So your saying you would rather have a bees dick more power on 50% throttle than overall at WOT ? You don't build your engine to cruise around as a daily most of the time.
Also where is the proof that you do lose power at 50% if you jump to 2.75". ? do you have any dyno sheets , comparison graphs 2.5 vs 2.75
I think you are missing the bigger picture here. Most Honda's built are daily driver 80% of the time. You want the low end torque and response to make it an enjoyable street car. Obivously once you step on it, you want the thing to move.
Who cares what size exhaust system you put on. I've seen car make power with crappy exhaust system. At the end of the day its up to the end user if they don't mind the level of noise of the exhaust whether it be 2.5, 2.75 or 3 inch
Hey guys,
My b20vtec is hooked up with a hondata s300 and the ecu is not enabling vtec with all wiring and hardware are fine..
could my ecu be playing up in anyway??
Cheers
