how much for the set of 4 mun if you dont mind me asking? can pm me if you want
oh and where did you get them from?
$110USD for these bro
http://www.ebay.com/itm/New-OEM-Genu...#ht_2570wt_929
CB knows, I bought a mint set off him, good price.
thanks CB.auto, great service
install oem mudflaps to eg hatch
paint stripped plus wire wheel b series rocker cover, waiting for 2 -10an bungs to arrive to be welded on cover for catch can setup.
will be spraying rocker cover metallic bronze!
slowly prep for my next wsid .. :(
removed motor last weeknd
http://img189.imageshack.us/img189/7921/motorok.jpg
Uploaded with ImageShack.us
shave the block for more shaft clearance
http://img208.imageshack.us/img208/5083/blockok.jpg
someone else doing a h2b aye? whats the plans for this build?
http://i.imgur.com/oU6E4.jpg
new headlights...
my plan basically still the same the car will running stock h22 motor but this time with new clutch, lighthen flywheel, cam gear, new seal because too much oil leak, new hasport mount, hondata etc
Where you getting all your h22 seals from? I found it hard getting seals for Jdm h22a when I was putting together my h2b cause most of it is discontinued
