		?!?!?! really?! i got it running, home made light tester haha, my white wire was power, i got 3 speakers running, but have no clue wat wire is my acc power. I've tried all the different combinations but its not working for me. Only 3 speakers are running atm. Not to sure what to do.
		take a pic and show us your wire loom...ill show you what they're meant to be
 I think the white wire is constant power so you don't wanna use that one
 Try this?
 :Radio Harness
 +12V DC Constant White
 Switchedd Accessory Violet
 Ground Black
 Power Antenna Gray
 Remote Turn On Light Blue
 Illumintation Red/Black or Gray
 Left Front + Light Green
 Left Front - Pink
 Right Front + Gray
 Right Front - Brown
 Left Rear + Yellow
 Left Rear - Brown
 Right Rear + Blue
 Right Rear - Orange
		Shouldn't the massive wires be power? Should'nt be too difficult to find which one is live right?
 Tim needs an orange lip kit
		just sprayed my calipers blue...
 got cbf halfway through and rushed it
 looks alrite still
		thanks xenon that helped heaps.
		anyone changed their fd1 front and rear brake discs and brake pads?? any recommendations? coz honda said i need to change my rear brake pads and get the discs machined coz it's out of alignment...
		my car has done around 45k with the stock pads. i thought they might be due for a change.  asked my mechanic to check em while he was doing a service and said id be able to get at least another 30k out of em. (hybrid driving tho lol)  stoked!!
		Yeah same here. I'm on 47,000km and my brakes are still 80% but they may have been changed...
 ^danny I recommend if you want to upgrade your rotors get some aftermarket cross-drilled or slotted ones. Will probably cost less than OEM but look much better.
 However if you want to save your money just machine your current ones...should have plenty left on them
		Anyone know where to get long anodized lug nuts that aren't rays? They're so expensive
		3 Attachment(s) pics
		get some slotted rotors if you need to change them.
 If your after cheap pads go for lucas or bendix pads. If you're want abit more force then have a look at intima brakes or hawks HPS
		http://i745.photobucket.com/albums/x...11b12b69a2.jpg
 i need coil overs bad!! damm this saving up shit! (baby on the way) lol
