autobarn...2bux each.
repco...around same price, they can order them in for you.
supercheap also had it
try your local auto shop, they all should have it. if not. they can order it for you. you just have to wait.
yeh imma go supercheap auto now at rockdale ..
thanks ek4r
ey guys .. i went to supercheap at rockdale and auburn ...
dey say that they dont stock the sockets in-there store anymore ..
autobarn in auburn is shit .. (they dont know anything) they never have stock ...
REPCO is the best .... went to auburn repco.. he said he will get it for me tomorrow...
THANKS guys
^ good to know. hopefully you have your sexy lights running by tmrw. GL
ok i followed all the instructions. The problem is now that of the two new lights that i have installed. One of them is exceptionally brighter ?? :confused: while the other one is the same brightness as the rest. Keep in mind that both are new bulbs and such.
Any ideas on how to fix?
note: the bulb that is bright, is the right hand side + its brighter than the rest during parker... as well as brake lights
any help thanxs
http://www.ozhonda.com/forum/showthread.php?t=16752
Just in case anybody wants to see another version of this guide. One thing, we have reflectors in the lower drivers side portion needs removing for even illumination. I have the rear fogs on my drivers side lower section and brakes on upper.
I also went and bought usdm tails, like them better than the jdm/edm/audm tails. are a tad different.
At Dell - do you have a rear fog on the drivers side? if so, it is the reflector inside ... taking it out is a pain. but doable. keep some silver paint handy for the scratches you are about to make ;-)
Kristin
thanks for ur input i was wondering is there anyone out there that would help me. The car is just a standard EK1 plus its only one side is brighter.. Thus if there was fog lights wouldn't it effect both
hmm could be a faulty bulb? i know they are some bulbs with different intensity. mine turned out even...
well i guess i will try to get a new bulb first... but if it is the fog light can u tell me how to remove it or at least fix it pls?
well, most likely you put in the wrong bulb, the reflector is noted when you look into the hole ... you cannot miss it as it is a second item in there ... you take it out with two pairs of pliers and a screw driver, it is made of some plastic and needs to be broken into pieces and taken out through the hole. painful process, go slow ...
ar crap.. Well i guess i am going to switch the new bulb with the old one that is no the brake lights. If just as bright then dam.... got to get out the tools n break that reflector.. If not.. easily solved.. get new bulbs
sounds good ya think?
