lol thx im going with castrol edge 5w30 oil :)
im using elf for my vtir prelude..
and also a lot of s2k using elf as well..
For oil wise, is genuine oil always better?, i just got mine serviced with penrite synthetic its not that bad, however i had castrol edge and honda genuine oil as well, but i found the castrol edge much better. just wondering if genuine is always better
thanks
haaha you answered your own question.
in my opinion mineral is really only good for running new engines in...after that running synthetic is better. I prefer Castrol Edge because it meets all the requirements, comes in the right viscosity and is priced decently.
(mineral oil being genuine honda FEO)
for the guys that have used both FEO and Castrol Edge 5-30 or similar.. does Castrol or Synthetic oil burn much faster than FEO ??
when i was using Edge it used to burn heaps.. every fortnight i would probably have to fill up a bit as it would drop to half way between the H--L .. with FEO it doesnt seem to burn that much at all.. it has been a month or two and ive lost barely 1/4..
in general the more you hit VTEC/high revs the more oil you burn.
cleaning the pcv valve on the rocker cover has pretty much eliminated my oil burning. I clean the valve every 3 weeks
ok cool.. thanks guys.. i've got FEO in mine at the moment, but i'm planning on flushing that out tomorrow and put castrol edge 5-30 in.. guess i'll have to stock up on the oils when they're on sale..
i don't have any idea how to clean the pcv valve on the rocker cover.. so if it's an easy process to explain jbird, it'll be great if you could advise.. if it's too complex.. dw bout it..
Positive Crankcase Ventilation valve
You can either clean it or replace it. The one in your car should make a rattle sound when you shake it. If it doesn't it means its clogged up with oil.
Carburettor cleaner is a good way to clean it. Spray it liberally inside and dry with a cloth/tissues.
1. pull out of rocker cover
2. disconnect it from the hose using bullnose pliers
3. clean the valve. (not the engine or rocker cover!)
4. dry
5. reinstall.
should take 10minutes at most.
i just did an oil change and oil filter change .. it originally had FEO in it.. but it was fairly black.. now it's got golden Castrol Edge 5-30w and new OEM filter.. now it's driving like a dream.. woot woot..
hey guys.. supercheapauto have Castrol Edge 5-30 on sale.. it's only $39 at the moment..
