i read on the first page you running ctr cams are you still using them?
sure are, the setup is identical to the first page except i changed to a edelbrock inlet manifold, 2000cc injectors, deautschewerk DW301 fuel pump and wound the boost up another 5psi.
also fitted a parachute so i could turn off the speed limiter that i had set to keep it under 140mph.
Nutz!!
forgot about that go pro footage i got of you a while back,ill get it to you when i can!
Bet you have a itch for 9's now eh!
wow very impressive!
nice! congrats impressive numbers, i was checking your car out in the staging lanes good stuff keep it goin!
pwah what a jet.
i see you wrote that you got ls2 coilpacks, is it big bucks going from a dizzy to coilpacks? and was there noticeable improvements ?
All it cost me was the price of the coils which from memory i payed $200 for 8 of them of ebay. i made everything else for the conversion myself and a mate wired it and the link computer was capable of doing 4 ignition outputs. there wasn't really any noticable gains but i had to run very small plug gaps (with the factory ignition) to avoid spark blowout and this was when it was only on 25psi. the standard ignition would have struggled on 30psi.
Congratulations, fantastic to see someone doing so well with a self built car. Must give you immense satisfaction! Nines now beckon :cool:
Can anyone think of any other manufacturer's product that could turn those numbers with so much standard product still in the car??
And it is great to hear your success with the Darton sleeves, as I have had very sour experiences with two blocks done locally [WA] that were an embarrassment to the name of good engineering.........
