I took that switch out when I did all my wiring, its not really required. If you are still using the ED underdash wiring you can just solder them together, if you're using an EG underdash harness there won't be a plug for the switch as I don't believe EGs have a clutch switch in AUDM models.
You can download those manuals for free from here: http://hondatech.info/downloads/Auto/Manuals/. Or from http://www.spoonertuner.com/manuals
There is an ED6 specific wiring one, I used it when I did my swap as the EF manual I presume you have does have some slight variations from the ED6.
Yeah im converting everything in the car to an EG harness, including the underdash, with a CRV cluster as i got an electric VSS now.
Not sure which ED manual i have, but its ED as the cars are carby, EF is JDM and EFI only, right?
Another slight issue, i had a tarp in the car port covering 1 full side so that the rain doesn't get in. I had weights holding it down, my brother took them out and put a brick there, the stong wind pulled the tarp off and sent the brick through my rear window :(
