a puncture?
His logics correct.By 'safe' he means unreliable, more likely it could fail. The tire is stretched past its limits thus making it more potential to fail, making it unsafe.
The moment you increase boost the moment it comes more unreliable then stock. Like anything in this world if its put outside of its limits it will become more likely to fail.
Tires were not manufactured to do that.
The stuff that keeps you connected to the ground should kind of be a priority.
Common sense kicks in for most people before they run a tyre with an outrageously unsafe profile.
On a tyre with a lot of stretch, the sidewall contacts the road when cornering. That part of the tyre is not supposed to wear and is critical to handling.
exactly, the motor was not designed to take more than what it is. increasing its boost increases your chance of failure. im glad you see the logic now.
^exactly
yes of course, if you can show me any situation where 'upgraded brakes' were the sole cause of an accident then i'll concede to you. i've seen many an article of stretched tyres debeading while moving. by some miracle of god nothing happened, but if that were to have exploded? or completely left the wheel? then what?
^not only critical to handling but safety. the sidewall needs space to flex, take away it away from its intended use, and reduce its space in which the sidewall can flex and its a hazard. stretch is not and never will be safe. i understand you're all stance|works and all that jazz, but endangering yourself or other human beings so you can stance your nuts off, or get wheels that shouldn't your car to fit, by using the wrong size tyres is wrong.
still not understanding the concept of within limits.
I dont have any pictures for you nor stories, The main reason would be because i dont hang around fanboy enthusiasts who think its cool to put -10 camber, massive offsets with stretched tires and ridiculous number plates on their cars. But im sure there are fails and when it happens it is quite unsafe.
edit: umad?
I know stories of stretched tyres coming off the rim during cornering.
Buy nice wheels, run cheapest tyres that stretch on them. Nice.
