I just had a google, D16Z does not come with EGR
http://i57.tinypic.com/j7u3w4.jpg
http://i61.tinypic.com/1z56btj.jpg
If you need more photos i can take them :)
WOT is always fine.
Checked the radiator and there's no bubbles so it doesn't look like there's a cracked head.
The ignition timing might be a cause. i went to do it today but can't do it because i can't find the little plug thing to cross-wire before a looking at the timing.
http://i58.tinypic.com/6htkjo.jpg
http://i62.tinypic.com/10dwpid.jpg
i just cleaned the intake manifold. man, it had nice coat of black crud.
I might take if for a drive later to mcD's and see how that goes.
but i do have another question....
there was this hose that goes from the top left corner of the valve cover into the intake. i suspect this is the case if the crud.
Does anyone know if i can remove it? can i just add on of those valve cover external oil filters??
http://i62.tinypic.com/122gtol.jpg
stupid pipe spewing shit in my shit.
Jimper wire
Interested in knowing how she got a fuel pump in there. If all ed3s are carb, was the tank replaced from the concerto or pump added to the existing tank?
Nice car, good to see some of these still knocking around.
OK I've learnt some new things about this bogging down at 2,000
Exhibit A
I have 2 of these problems.
"difficult to start cold engine" & "poor performance - loss of power"
I know the injectors are good, I've already changed the fuel filter for a new one so the only other thing that is mentioned in both of these issues is the fuel pump. That being said, i've disconnected the fuel line from the fuel filter and it seems to prime ok...
http://i58.tinypic.com/2iafthk.jpg
Exhibit B
The lag at 2,000 seems to happen more when the engine bay is hot. so it happens more on hot days, and it happens more after running the engine hard. This leads me to believe it might be an O2 sensor failing as it gets hot.
But no, there is no CEL on.
maybe its heat soak lol
