Originally Posted by
gbpracing
			Ok here's a breif breakdown of the engine build....
B20 block with 85mm forged 12:86:1 comp,
over 12.5 is a good start, brand? design? P2W specs?
 i am running CP.
Carillo H beam rods,
excellent.
3.5 kg flywheel with 7.25" Tilton hydro concentric twin plate clutch,
clutch is personal choice, but that sounds stout.
(i run exedy hyper carbon)
 Crank is knife edged hardened and balanced with all clutch and f/w.
what clearances?
B16A full race ported head with 285cfm @ .500",
mine head is 300cfm @.500
 34mm Intake valve 29mm exhaust valves.
i think unnecessary, but can help in boosted application, did soemoen talk you into this? or your idea?
 Toda C2 Cams ,
these play nice with 2L and quads
(i am running std intake (fully ported by Endyn) and 65mm TB)
Toda 4-2-1- race headers,
should be perfect
(i am on bisimoto)
4x 48mm throttle bodies,
a bit small for 175kW? but mid will be great...
 Autronic engine management system.
tuners choice? Hondata is fine for most cases...
 Using 105 race fuel.
will help!
 450cc injectors,
i am runing ID725cc in mine, but 450 will be OK with lots of pressure
Bosch VL turbo Motorsport HP Fuel pump,Sard fuel pressure regulator,
both OK, but also a surge tank?
If thats not enough info let me know what you need to know !
