Try mobil 5w-30, its one of the best oils out there. But it is a bit pricey.
I think you're fuel light is coming on early than it should be.
The ep3's tank is 50L. I fill up 43 Litres when my fuel light comes on.
If you're only filling up 35L. You got 15L lefts.
I do about 450-480km for 43L. From your posts, you're doing 340km with 35L. That's sounds normal to me.
well i use motul 5w40, and its going really well. i was using the motul 300v before but its too damn costly and got the motul 8100 xcess instead. couldnt tell a difference between the two and both have pretty much the same life, regardless i always have to check up engine level every fortnight at least, these k20's burn oil like no tomorrow and i barely gun the crap out of my car.
Dose any1s EP3 blow smoke when you give it some but i mean when you give it hard Vtec it from gear shifting like drop from 5th to 3rd?
I've drained it changed all oils and even slapped in a K&N filter its been ok lately but still a bit of smoke comes out..
I have a funny feeling the Kms on this car were tampered with cause my clutch is close to been gone (not from me it was like this in the beginning) and i had to change a wheel bearing. I got this car at 38kms.. wheel bearing last a hell lot longer then that.
Not sure if mine still black blow smoke on vtec. It did when my o2 sensor died as I suspect it would had ran rich. Replaced it and I haven't heard any of my friends saying I was blowing smoke.
From my own research, It's also important that you take notice of the color of the smoke. Black smoke isn't a big deal as it just means unburnt fuel. Faint white steam should be water condensation. It should only occur when engine is cold and usually happens in the morning.
Heavy white smoke = blown gasket (Burning engine coolant).
Blue/Dark Grey smoke = Burning oil (Maybe due to worn piston rings)
And for the odometer, I would doubt that the kms are original considering of EXTREMELY easy it is to replace the cluster.
lol did i just get neg repped cause i said hasport > innovative ?
any1 using royal purple?
